Visitor poelslager
How do you program the ELF to flash? - VC707 Vivado 2017.1
Vivado 2017.1 w/ SDK
VC707 Evaluation Kit
I am using the Base Microblaze example project, and the 'Hello World' template without any major modifications.
The mt28gu01gaax1e-bpi-x16 is added as a configurable memory.
I am having two problems:
1.  I can't program the FPGA or flash from Vivado, only the SDK's 'Program FPGA' button will work.  Vivado 'thinks' that the programming completes without error, but it doesn't seem to work. Attempting to use the MCS or BIN file to configure the flash from Vivado results in  the following error:
boost::filesystem::system_complete: The filename, directory name, or volume label syntax is incorrect: " "
2.  The SDK's 'Program Flash' button doesn't work, even though it takes a while and completes without error.
Can somebody give me a rundown of what steps I need to complete to program the flash to start up with the code from the SDK?
Pete
Visitor poelslager
Re: How do you program the ELF to flash? - VC707 Vivado 2017.1
I got it working. Please delete this thread.
Visitor poelslager
Quick edit: Vivado will program the .bit file, but not a .bin file. Even though I removed the .elf from sources and regenerated the bitstream, the code from the SDK is still there. I still can't program the flash.
Visitor poelslager
And the last thing I can think to add: Generating an MCS from the bitfile results in the following error:
'[Writecfgmem 68-4] Bitstream at address 0x00000000 has size 20273436 bytes which cannot fit in memory of size 2097152 bytes.'
Visitor poelslager
Scholar pratham
@poelslagerWe don't usually delete the thread unless needed. You need to close this by marking your own post as accept as solution.
-Pratham
Participant mfryba
Instead of just saying "I got it working..." it would have been useful to the rest of us to describe how you got it to work.
Participant mfryba
Thanks for kudo, I think I have the recipe:
1. Add the ELF to your Vivado project (under Add Sources)
2. Associate that ELF with your MicroBlaze (right click on the ELF once it's in the source tree).
3. Build your "final" BIT files in Vivado instead of SDK (ignore later SDK complaints about your hardware export being out of date).
4. Then create the MCS file as usual in Vivado. For the VC707, I found the "Restore MCS files to Flash" examples helpful (especially the TCL scripts) to understanding the layout of the flash, and how to store different BIT files into the 4 available sections.
