Visitor vsheladiya
How to Delay Internal Signal?
I was going through 7-Series HDL library guide. I found that it has IDELAYE3/ODELAY3 to introduce a delay. But also it looks to me that it can only be used to delay input or output, not internal signals. Is it so?? If it is, then is there any other option to provide delay to internal signals?
Vijay
Scholar dpaul24
Re: How to Delay Internal Signal?
You can use IDELAY/ODELAY on internal signals.
But it seems like you did not pay attention to my post#2.
Every I/O block contains a programmable delay primitive called I/O-DELAY*. The placement of a DELAY module is fixed. So if you connect an internal signal to a DELAY module, have you considered the fact that you need to route your internal signal to and from the DELAY which is sitting on the edges of the chip? What do you think will be consequences on your timing analysis?
>>But what if I want to add delay to some internal signals which are belongs to internal logic and not going to or coming from out side of device.
Also I still don't understand this. An internal signal which belongs to internal logic also belongs to an internal clock domain. This internal signal must be in sync to that clock. Won't the use of a DELAY here make the internal signal go out of sync with your internal clock?
Or wait..... are you trying to use a delay module because you want to sync this internal signal with your internal clock?
I think  for getting a better answer, you need to explain why is it needed to delay the internal signal.
The primary purpose of IDELAY/ODELAY  modules is not to achieve what you want to do (adding small delays to internal signals). I am just giving you a premonition of can happen at the timing analysis stage.
FPGA enthusiast!
All PMs will be ignored
Scholar dpaul24
Why do you want to delay an internal signal?
Are you writing some *combinatorial only* logic?
If not (i.e. you are working with sequential logic) then this internal signal of yours must belong to some clock domain. Then this signal of yours must be transiting when the clock toggles. Adding an intentional delay to such a signal will be a serious mismatch.
So for sequential logic design, in order to delay an internal signal, just passing it through a flop will give it one cycle delay. For more delays. more flops.
As far as I know I/O-DELAY* Xilinx primitives are placed at the FPGA chip peripherals and they are used to add an additional delay to the data so that you do not violate setup/hold timing of the input register (for IDELAY) or the off chip synchronous element (for ODELAY).
FPGA enthusiast!
You can use flop internally to delay signal by clock cycle. you can write FSM to latch signal based on some signal assertion conditions.
For example this process delay input by one clock cycle . Q and delayed_input can be internal signals
library ieee;
use ieee.std_logic_1164.all;
entity registers_1 is
port(C, Delayed_input  : in std_logic;
Q : out std_logic);
end registers_1;
architecture archi of registers_1 is
begin
process (C)
begin
if (C'event and C='1') then
Delayed_input <= input;
end if;
end process;
end archi;
Thanks and Regards
Balkrishan
Visitor vsheladiya
Thanks for your quick response..
One cycle of delay is too big for me, I need to add fine delay like IDELAYE3/ODELAYE3 introduces. Actually I need it for implementing DDR memory controller. So there apart from IOs, my internal control signals also needs some delays, that's why.
Thanks & Regards,
Vijay
You may use Xilinx MIG memory controller IPs. To implement delay refer this ARs
https://www.xilinx.com/support/answers/60802.html
check this related post
https://forums.xilinx.com/t5/Spartan-Family-FPGAs/iodelay2-min-max-delay/td-p/116418
Thanks and Regards
Balkrishan
Scholar dpaul24
Yes in that case use the DELAY* primitives.
All the best for timing analysis.
Recommendation is to use the Xilinx IP core as told above in order to avoid STA nightmares.
FPGA enthusiast!
Visitor vsheladiya
Hi Balkris,
My question is not about min/max delay values what IODELAY can introduce. Also I don't want to use MIG Memory Controller. I want to implement my own customized memory controller. So I wanted to know that apart from IOs, can I use IODELAY to introduce delay to my internal signal?
To make it more clear, lets say I have number of inputs and outputs in my core and also I have some internal logic. So using IDELAYE3, I can add delay to all my inputs, and using ODELAYE3, I can add delay to all my outputs. But what if I want to add delay to some internal signals which are belongs to internal logic and not going to or coming from out side of device.
Thanks & Regards,
Vijay
Scholar dpaul24
FPGA enthusiast!
what sort of delay is needed, 10's of pS 100's??
If you are doing a customer memory controller is there a reason why you are not using MIG?
For the Delays there is a fabric in an out port that can be used, have a look at the DATAIN and DATAOUT ports:
"Data Input from the FPGA Logic - DATAIN
The DATAIN input is directly driven by the FPGA logic providing a logic accessible delay
line. The data is driven back into the FPGA logic through the DATA OUT port with a delay
set by the IDELAY_VALUE. DATAIN can be locally inverted. The data cannot be driven to
an IOB.
Data Output - DATAOUT
Delayed data from the two data input ports. DATAOUT can drive to either an ILOGICE2/
ISERDESE2 or ILOGICE3/ISERDESE2 block, directly into the FPGA logic, or to both."
From UG 471 page 117: http://www.xilinx.com/support/documentation/user_guides/ug471_7Series_SelectIO.pdf
Visitor vsheladiya
I think this would be good enough for me as of now. Thank you.
Thanks & Regards,
Vijay
Observer mik3l3_hdl
Hi @jheslip , guys ,
In my design an internal signal "A" is compared to a similar signal " B"coming out from an external device FMC pins and IDDR .
So the path is   external defice FMC -> my device FMC -> IDDR ->register -> signal B.
Signal A and B are both 90 bit signals. Each signal is composed by 3 counters  concatenated A <=(counter1 & counter2 & counter3).
I made B passing throug a register because i noticed that without it the singal B data packet, during simulation appears with some transitions.
(i.e.  rather than beeing  <100001 200001 30001> it appears as <00000> <100001 200001 30001><010001>).
To compare A and B , i basically delay signal A with some register such that bot packets (A and B) are alligned .
A is synchronized with the internal clock clk0 while B is synchronized with an external clock with same frequency of clk0 but phase shifted of 90deg (so i called it clk90).
In Behavioral simulation the packet are alligned.
Basically my design is what described above : internally generates A and then compares it with B coming from an external FPGA.
So I have two similar designs one per FPGA   . So FPGA1 and FPGA2. connected throug parallel bus FMC cable. Both receiving the external clock from external clock distributor.
In Behavioral simualtion the data packet A and B results alligned so the error detected is zero (is zero whe 2 packets A and B are the same else is 1).
and the delay between the packets is less than 1 clock period =5ns specifcially 1.241ns and excludes the raising edge so no error detected).
BUT in POST-SYNTHESIS FUNCTIONAL SIMULATION  the delay is 3.41ns and includes a rising edge so the error is detected.
Indeed when I run everything on the real FPGAs the error detection led is turned on.
How I can reduce the error of 3.41ns detected in Post-Synthesis simualtion  to 1.241ns detected in Behavioral simulation ??
Thanks in advance
