How to generate 100khz sqaure wave synchronous to GPS 1pps with 10mhz as input with PLL or MCMM
inputs are 1PPS from GPS and 10Mhz i have to produce 100khz with is sync to 1pps
ie there posedges shouls be coincided
Is your 10MHz synchronized to the 1PPS?
