06-22-2018 10:26 AM
I am programming a Artix-7 FPGA (xc7a15tftg256-1). I have been trying to upload the program onto the external configuration flash memory. However, after successfully uploading the .bin file to the flash memory, I will cut power to the FPGA and then turn it back on and it will not run the program I just uploaded. It runs something else. When I manually click boot from configuration memory in Vivado, it does work though. How do I configure the FPGA so that it will always boot from configuration memory when the power is cycled?
Thanks!
06-22-2018 12:03 PM
Hi Alexander,
the boot method is decided by the Mode Pins M0 M1 and M2.
Please refer to the UG470 "7 Series FPGAs Configuration User Guide".
Have fun,
Sebastian
06-22-2018 12:03 PM
Hi Alexander,
Have fun,
Sebastian
06-22-2018 12:12 PM
You should check the mode pins ( M2, M1, M0 ) to see how they are set. These control the boot mode when power is cycled.
