IO port pullp/down resisitor
Hi, I have a input port which is LVCMOSS33 in kentex7 fpga, what is the default pullup or pulldown resistor? if I change to PULLUP True or PULLdown True, what it will be? Thanks
@jumper_qb This is it
https://forums.xilinx.com/t5/Silicon-Devices-Others-Archived/Pull-up-and-Pull-down-value/td-p/16564
-Pratham
Checlk FPGA family datasheets DC specification tables
https://www.xilinx.com/support/documentation/data_sheets/ds182_Kintex_7_Data_Sheet.pdf
Refer these document as well for detail usage
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug912-vivado-properties.pdf
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug974-vivado-ultrascale-libraries.pdf
Thanks and Regards
Balkrishan
thanks,is the data apply for the default value, what's the value when I set_property PYULLUP TRUE....
PYULLUP TRUE. means VIN = 0V, VCCO = 3.3V check DC values in target device
Thanks and Regards
Balkrishan
@jumper_qb This AR https://www.xilinx.com/support/answers/67577.html pretty much answers what you are looking for. It explains with example.
- Giri
There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered.
Keep conversing, give Kudos and Accept Solution when you get one.
understand. then what if I didn't set pullup true, is there any pullup or pull down there?> Thanks
@jumper_qb By default it should be "None". Only if you set, it will get applied.
- Giri
