ISERDES clocking in oversample mode
when using a MMCM to create the 4 clocks needed for OVERSAMPLE mode of ISERDESE2, we get a partial routed error with no further explanation in Vivado 2017.3.1.
We use following clocking structure:
 MMCM -> CLKOUT0 for  CLK, CLKB of ISERDESE2, connected via BUFIO
 MMCM -> ClKOUT1  for OCLK / OCLKB of ISERDESE2, connected via BUFIO
Do we have to connect ISERDESE2 in another way?
Hi @fuxx_14 :
CLK and CLKB are driven by a BUFIO. OCLK and OCLKB are driven by a BUFIO which should be phase shifted by 90°. The two BUFIOs should be driven from a single MMCM.
Can you share your clocking topology screenshot here?
What is the error you are getting? Share the log file as well.
Priyanka
We exactly used that clocking topology. The routing error is caused by using the BUFIO clocks which are also used as shift clock (ISERDESE2 outputs are driven by CLK), but BUFIO cannot drive CLBs.
So we tried to shift the 4bit ISERDESE2 output data in order to get a parallel bus of oversampled data.
So how should we get the oversampled data?
Using two BUFGs instead of two BUFIOs for clocking? Are there further recommendations?
