Kintex Ultrascale OSERDES clock configuration
My clock question follows very closely to this existing forum post:
https://forums.xilinx.com/t5/Other-FPGA-Architecture/Kintex7-OSERDES-High-Speed-Clocking-with-MMCM/td-p/564351
Since the wording of the documentation is not very clear in terms of what can be a valid correct clock configuration with the BUFIO/BUFR setup, can someone confirm which option below is the recommeded connection to the OSERDES?
Note for option 1, the BUFR would use the divide attribute to have the clock at the correct frequency for the data. Option 2 was tried but unfortunately produced bit errors at the output.
Re: Kintex Ultrascale OSERDES clock configuration
Hi @mphanav
As i can see you have filed SR for this issue and i have replied to on SR communication.
To summarise.
Option 1 is the valid clocking topology to minimise the skew between CLK and CLKDIV.  (BUFR and BUFIO  can be driven by  MMCMs clock outputs 0-3)
Reply if you have any queries, give kudos and accept as solution
