vza11033
Kintex7 LVDS input common mode voltage
In application note XAPP894 P11,
I found that the common mode voltage of LVDS receiver in FPGA can drop to 100mV.
Can I use this function on Kintex7 ?
gnarahar
@vza11033 Yes, it can drop to 100mV provided you use external termination resistors. This is done to have the Common mode in range of DPHY SLVS standard
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
kkn
gnarahar
- Giri
