852398348@qq.com
Kintex7 XADC config
Hi XILINX engineers!
I am using your FPGA on my project. I will not use the XADC moudle. So the question is :
What should I deal with the VREFP_0 VREFN_0 VP_0,VN_0,VCCADC_0,GNDADC ?
umamahe
For VP_0, VN_0, DXP_0, DXN_0 connect to GND according to the  XADC User Guide pg 14:
http://www.xilinx.com/support/documentation/user_guides/ug480_7Series_XADC.pdf
"This pin should be connected to GND if not used."
kkn
umamahe
