LVDS DIFF TERM Serie7 FPGA
If I use the attribute DIFF_TERM = TRUE into LVDS standard input in a HR bank not powered at 2.5V or in HP bank not powered at 1.8V what exactly happens?
The LVDS input in those conditions is supported if DIFF_TRUE = FALSE but if I put  DIFF_TERM = TRUE the differential termination is not guarantee precisely at 100 ohm (as the correct case) or can I cause a damage for the FPGA?
And if I not cause a damage for the FPGA how much is the differential resistor value for the HR and HP banks if not powered precisely at 2.5V and 1.8V respectively?
Re: LVDS DIFF TERM Serie7 FPGA
Please see https://www.xilinx.com/support/answers/20004.html
Simon
Simon
thaks for the answer; so from this sentence.
"VCCO supply other than 2.5V results in a non-ideal termination, and is not recommended or supported."
I have understand that the termination is not exactly 100 ohm for this reason is not ideal and not recommended but it is something similar and, if I do this, I have a not ideal termination (bigger or smaller 100 ohm) and I do not cause any damage at the FPGA.
Is it correct?
Nicola
Hi Nicola,
It is correct.
Simon
Simon
