ogutzwiller
LVDS sys clock on VC707
I'm implementing a simple VHDL program using for a VC707 eval board and have difficulties to use the system clock.
The clock is a LVDS 200 Hz clock. I have defined the SYSCLK_P/_N pins in the XDC file. It is needed to instantiate differential input and output buffers in the code.
Do you know how I can instantiate a LVDS buffer in a VHDL code ?
Thanks foryour help, Olivier
siktap
IBUFDS_inst: IBUFDS
 generic map (--DIVISOR => 2604,
   DIFF_TERM => TRUE, -- Differential Termination
   IBUF_LOW_PWR => TRUE, -- Low power (TRUE) vs. performance (FALSE) setting for referenced I/O standards
   IOSTANDARD => "DEFAULT"
  port map (
 O => sys_clk, -- Buffer output
 I => sys_clk_p, -- Diff_p buffer input (connect directly to top-level port)
 IB => sys_clk_n -- Diff_n buffer input (connect directly to top-level port)
Tags (2)
siktap
IBUFDS_inst: IBUFDS
  port map (
Tags (2)
htsvn
Refer to the code available in page 171 of this document
http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_4/7series_hdl.pdf
Library UNISIM;
use UNISIM.vcomponents.all;
-- IBUFGDS: Differential Global Clock Input Buffer
-- 7 Series
-- Xilinx HDL Libraries Guide, version 13.4
IBUFGDS_inst : IBUFGDS
generic map (
DIFF_TERM => FALSE, -- Differential Termination
IOSTANDARD => "DEFAULT")
port map (
O => O, -- Clock buffer output
I => I, -- Diff_p clock buffer input (connect directly to top-level port)
IB => IB -- Diff_n clock buffer input (connect directly to top-level port)
-- End of IBUFGDS_inst instantiation
--Hem
Tags (2)
athandr
In addition you can also use the selectio wizard to generate the code for input/output single_ended/differential buffers for data and clock for verilog/vhdl.
Anirudh
Tags (2)
umamahe
Please refer the below link document which has all coding templates including LVDS buffer in VHDL code
http://www.xilinx.com/support/documentation/sw_manuals_j/xilinx14_7/7series_hdl.pdf
rajuponnaganti
Voyager
Voyager
Can I use this clock as GTXrefclock or Init click by using DCM(Clock management)?
yenigal
NO,using MMCM or PLL to generate the reference clock to transceivers is not recommended.
http://www.xilinx.com/support/answers/53500.html
You should use a high quality clock source directly driving this and the VC707 user guide gives you more details on this clocking options for the transceivers.
Satish
bcarltontrex
Specifically you need
IOSTANDARD => "LVDS
or
.IDOSTANDARD("LVDS")
