shuo_shuo
MIG pin assignments
Hi experts,
I'm designing a board with XC7K325TFFG900C-2, MIG will be used to generate interface to control a DDR3 SODIMM. The data width is 64 bits, and I'm going to connect it with bank 16, 17 and 18. In this way four byte groups (T0-3) will be connected with bank 16, all control signals are connected with bank 17 and the other four byte groups will be connected with bank 18.
I think different pin allocation in GUI will have different pin assignment, can I just connect all 44 signals of four byte group (e.g., DQ[31:0], DM[3:0] and DQS/S#[3:0]) with bank 16 randomly? I mean I will not use the pin assignment result from MIG, just connect them with bank 16. I'm sure the DQS signals will be routed differentially. As for complile in VIVADO, I'll update the ucf file accordingly, is this feasible?
I just listed two examples of MIG, I also found there was no specific requirement for pin assignment in MIG.
Chris
vsrunga
@shuo_shuo
You can refer UG586 deisgn guideliness section for MIG placment rules, you need to connect DM and DQS to respective bytes groups.
I would suggest you to modify the pin out as per your requirement, then go to MIG fixed pin out option and do read xdc and click validate, if there are any violations MIG reports them as errors and you can correct them accordingly else you are good to go.
Hope this helps
-Vanitha.
vsrunga
@shuo_shuo
Hope this helps
-Vanitha.
shuo_shuo
Yes, I can read xdc, I forgot that. I'll definitely connect DQS and DM to respective group. I guess it should be work, then it will be easier for my layout guy.
Regards.
Chris
