Maximize xc7z020 power consumption
How can I quickly and easily maximize the power consumption of the xc7z020? Does xilinx provide such a test program to maximize the power consumption of the xc7z020?
Re: Maximize xc7z020 power consumption
Hi owave_hy@163.com
Xilinx doesn't provide you the power consumption figures directly in the docs as it varies from design to design. Maximum power consumption means maximum utilization of the resources.
You can dowload the Xilinx Power Estimator spreadsheet, select for your device.  Guess  how much logic, IO, etc. you will use and what clock frequencies (through Quick estimator tab) to get the max of the power consumption.This will estimate the power for you.
After you have your design ready, the ISE or Vivado tools will also calculate the power report for you.
Rohit
Hi owave_hy@163.com
Rohit
