Visitor iori33
Measuring power consumption with Virtex-7 vc707
I am trying to measure the power consumption of custom IC, which is powered by "VADJ_FPGA" from the vc707 board.
Is there a way to measure it in mW or uW scale?.
Thank you.
Re: Measuring power consumption with Virtex-7 vc707
https://www.xilinx.com/support/answers/39037.html
This AR should help
Scholar drjohnsmith
put a multi meter on the supply.
power ( voltage and current ) measurement is not available in the chips,
Visitor iori33
It is fabricated and packaged chip I made. I built PCB board to test it.
It is powered by UCD9248 TI chip in Virtex-7 FPGA board. I used the power called "VADJ_FPGA", which is user controllable. I am asking if I can measure the current at a certain operating mode with the code in SDK or I can measure it with multi-meter on which part of the virtex-7 board.
put a multi meter on the supply. power ( voltage and current ) measurement is not available in the chips
Please, Don't do that.
We lost a very faithful VC707 by attempting this very thing...
It would be better to hook up the TI power controller and use the GUI software from TI to read the current output from this regulator.
Vadj would power a number of FPGA IO banks but you could always get an idea of the power consumption on these from XPE and subtract it.
Keith
Visitor iori33
Is there any helpful reference regarding the measurement of the Vadj?
I just need the difference so it will be very helpful if I can find any way of measuring the current of Vadj even though it is connected to
something else than the custom IC.
This AR should help
