NET partially routed. How to solve it?
I'm currently trying to build a clock tree which is:
CLKAp
CLKAn
Re: NET partially routed. How to solve it?
@timoteo.gbm
Can you please elaborate more on the query? I assume the nets are differential pairs which needs IBUFDS.
Please check the following link:
https://forums.xilinx.com/t5/Virtex-Family-FPGAs/How-to-use-IBUFDS-OBUFDS-differential-signals-buffers-for-Virtex/td-p/63576
https://forums.xilinx.com/t5/Implementation/Single-Ended-Clocks-and-P-N-pair/td-p/378713
--Syed
This post is a mistake, it's been elaborated already. I will delete this one, otherwise, please just delete it.
