wdecook
Net connections for unused GTX transceivers.
I am designing a carrier card for the PicoZed 7030. The design will not make use of the GTX transceivers at all. From table 5-6 of UG476, I understand that the following connections should be made for the unused transceivers:
MGTAVCC -> GND
MGTAVTT -> GND
MGTVCCAUX -> GND
MGTREFCLKP/MGTREFCLKN -> Open
MGTRXP/MGTRXN -> GND
MGTTXP/MGTTXN -> Open
MGTRREF -> GND
Three questions:
Can anyone verify that this is correct?
MGTVCCAUX is already connected to 1.8V on the PicoZed. Is there any reason to not leave this connected as is?
Is there anything on the PicoZed other than the transceivers that use MGTREFCLKP/N, MGTAVCC, and MGTAVTT? It would be a shame to make these boards and find out that the ethernet controller doesn't work.
gszakacs
Instructor
Instructor
If your board already has power to the MGT, then it's best to leave it.  Unused MGTs won't use much power.  The best recommendation is to treat this as a partially unused GTX quad, so just ground the unused MGTRXP/MGTRXN inputs.
-- Gabor
gszakacs
Instructor
Instructor
-- Gabor
venkata
The guidance mentioned in ug476 is correct
The clock on MGTREFCLKP/N ports can be used for fabric logic by forwarding it using a BUFG. This will be useful even when MGTs are not used in the design.
MGTAVCC, MGTAVTT are only used for transceivers.
umamahe
Also refer http://www.xilinx.com/support/answers/41451.html
