PLB support in kintex7 FPGA even using AXI-PLB bridge how to connect custom ip core to PLB bus in kintex7(xck7325FFG900
I created a design in xilinx EDK 14.4
Design was like :
microblaze interface with AXI bus to AXI-PLB 4.4 bridge(ipcore) to PLB44 , I want to connect to the custom ip core which has PLB interface  and porting on to kintex- 7 (XCK7325ffg900) FPGA custom board.
problem: If iam trying to create custom peripheral wizard  Iam getting the option of  creating the peripheral using  AXIlite/AXI interconnect/AXI burst transfer only, where my requirement is to connect to the  PLB bus only where my custom ip core has PLB interface only.
You might have to create a design with PLBv46 interface(Target an older device - V5), Generate your IP with PLBv46 interface using CIP Wizard. Copy the pcores of V5 design into K7 design pcores folder. Check your IP in the User Repository. Right Click over the IP and add into the design.
Let me know how this goes.
--Hem
--Hem
Thanks for your quick reply, as soon as i get the solution, i will post you the same on this, anyway
Thank you very much
