Photon detector connection to Zedboard
Hello Everybody! In my project I have to receive data from photon detector(Hamasutu H10682) to PL. So detector output is max +3.5 to min +0.5 V, is there any need of using level shifter between them? If yes,the level shifter I'am going to use MAX14850 through PMODs. Please correct me if there is something wrong...
Thanks in advance.
Scholar jmcclusk
Re: Photon detector connection to Zedboard
100 MHz is definitely too slow to catch a 10 ns pulse..
BUT.. there is a simple way to capture this into your 100 MHz system clock domain.
Bring the pulse input to the clock input of a toggle flip-flop.   Take the toggle output, run it through a 2 or 3 stage synchronizer, and then edge detect it.    This will produce a clean pulse in your system clock domain.    Code to do this is below:
entity pulse_detect is
   port(
       pulse_input : in std_logic;
       system_clk  : in std_logic;
       pulse_output : out std_logic;
end entity;
architecture rtl of pulse_detect is
  signal toggle : std_logic := '0';
  signal shift_reg : std_logic_vector(2 downto 0);
  attribute SYNC_REG : string;
  attribute SYNC_REG of shift_reg:signal is "true";
begin
process(pulse_input) is
begin
if rising_edge(pulse_input) then
   toggle <= not toggle;
end if;
end process;
process(system_clk) is
begin
  if rising_edge(system_clk) then
     shift_reg <= shift_reg(1 downto 0) & toggle;
     pulse_output <= shift_reg(2) xor shift_reg(1);
  end if;
end process;
end rtl;
Scholar jmcclusk
The level of the pulse output is fine (2.2 V typical), but you should make an effort to terminate the input with a 50 ohm resistance, since this a sharp and fast pulse.   The output pulse width is 10 ns, so you should be sampling this with at least a 200 MHz clock to avoid missing pulses.
Thank you for your reply . Actually I plan to put pulse counter with 100 Mhz, so you think is it still slow?
m,
Per the sampling theorem, the sample clock must be > 2x the event, so 250 MHz would guarantee you catch every pulse.
Scholar jmcclusk
   port(
end entity;
begin
begin
end if;
end process;
begin
  end if;
end process;
end rtl;
Thank you!!!
