Observer jubayer
Power gating feature not working
I will be very detail:
Part of my project requires the reading of uninitialized (power-up values) of BRAM in an Atrix-7 FPGA.
There are researches that exploited BRAM power gating and partial reconfiguration of Zynq 7020 FPGA. The procedure is pretty straightforward:
1. Load a partial bitstream with a BRAM instantiated and initialized. The static part has a UART module to send the data.
2. Load another partial bitstream that has no BRAM (I used some dummy logics with same I/O features as BRAM) [so it should disconnect the previous BRAMs from power gate]
3. Load third manipulated bitstream that has BRAM instantiation but no initialization. This time BRAM instantiated but initial values are deleted from FDRI block in the .rbt file [after 0x50xxxxxx command]. The header is adjusted accordingly. The FPGA gives me the value initialized at step 1! That means the FPGA is reading the RAM correctly but at step 2 it's not disconnecting the BRAM. In other words, power gating is not working.
Now the official documents say 7 series FPGAs are capable of power gating. That is uninstantiated blocks should be disconnected. But for my design, I do not see it. Also, since I deleted all the frames in the FDRI block [from partial bitstream], how the FPGA knows which RAM I am going to read? Is power gating not enabled by default in Artix-7? What am I missing here?
I would be happy to provide more information. Thanks for reading this long messages.
Visitor wzw0027
Re: Power gating feature not working
This is a very interesting problem . I am looking forward someone can answer this question.
ju,
The BRAM is tested with 0, 1, checkerboard, checkerboard bar, then loaded from the bitstream before use.  So, using BRAM for PUF is impossible.
Observer jubayer
Thanks, Alesea
Although the paper says we can, for the sake of argument I am assuming we cannot use BRAM for PUF application.
Then, I can see that the third step is not initializing the BRAM because it is reading values from previous steps. Why is the FPGA not turning off the BRAM in the step-2 even if the BRAM is not instantiated there? Why is it retaining values from a different bitstream?
-J
j,
There is a whole 'bram brain' that tests the bram, replaces any bad column (a bad bit) with a spare bit, and initializes the contents per the configuration.
Powering down this complex block, and powering it back on, is much much more than simply powering on and off a simpler ASIC dual port SRAM array.
Visitor wzw0027
