Problems porting linux driver from Xilinx 3.9 to Xilinx 4.1 for zynq pl peripheral
trying to port an existing (and working) device driver from linux 3.9 to linux 4.1 both from Xilinx GIT.
On the later, when the driver loads a word from the PL peripheral (via an AXI interconnect), the system freezes, as if the driver was trying to access an unmapped area (AXI not acknowledging the transaction).
Same access with same driver works great in linux 3.9, with same peripheral bitstream.
ANy idea ?
Thanks in advance
François
So I finally found out.
That was a clocking issue.
One of the change between linux 3.9 and 4.0 is the Common Clock Framework introduction.
By default, all the FCLKs that are not present in the "fclk-enable" bitmask in devicetree are deactivated when linux starts.
That's what happened.
Problem solved.
for reference :
http://lxr.free-electrons.com/source/Documentation/devicetree/bindings/clock/zynq-7000.txt
Hi francoislegal
Did you make sure device tree blob file and device tree by dtdiff or dtx_diff and so on ?
Thank you.
check the drivers and tips from these links
www.wiki.xilinx.com/Linux+Drivers
www.xilinx.com/support/.../xilinx2015.../ug1165-zynq-embedded-design-tutorial.pdf
www.wiki.xilinx.com/Standalone+Drivers+and+Libraries
http://www.xilinx.com/support/answers/51779.html
www.wiki.xilinx.com/Zynq+Linux
www.wiki.xilinx.com/Zynq+Emacps+Linux+Driver
www.wiki.xilinx.com/Zynq+Linux+USB+Device+Driver
www.wiki.xilinx.com/Linux+GPIO+Driver
Thanks and Regards
Balkrishan
Sure,
the devicetree is ok.
Again, if I boot a 3.9 linux, my driver works correctly, I can even access my PL registers using MD in uboot before booting linux.
The driver prints out the read DT address at boot and it is correct.
François
So I'm a little more lost now.
I tried to synthetise a design containing only one AXI GPIO IP from Xilinx, and I set it up at the same address as my PL peripheral.
Guess what happens when I boot linux 4.1.... I get that same crash while accessing one gpio (echo 875 > /sys/class/gpio/export && cat /sys/class/gpio/gpio875/value).
I checked again, I can still do md 0x7aa00000 in uboot to access the device before loading linux.
François
Problem solved.
for reference :
