sirius13
Problems with QSPI (zynq, zedboard, S25FL256S)
There is board with SoC Zynq-7000, i'm working with qspi flash memory S25FL256S. There is no problem when i program memory with bytecount 4, 8, 12 - amount multiple of 4.
What have i do to program memory with 1, 2 or 3 byte?
sirius13
The problem was solved. You can not write 1,2,3 bytes in automatic CS management mode. You need to set manual CS, and make next sequence. For example, we use command PP=0x02 with 3 bytes address, and we want to write 1 byte 0xAB at address = 0x01
1. Set flash WriteEnable, after execution of WE-command CS must be at 1
2. Set CS to 0
3. XQspiPs_WriteReg(QSPI_BASEADDR, XQSPIPS_TXD_01_OFFSET, 0x02);
4. Execute ManualStart();
5. Wait for TX FIFO empty
6. XQspiPs_WriteReg(QSPI_BASEADDR, XQSPIPS_TXD_00_OFFSET, 0xAA010000);
7. Execute ManualStart();
8. Wait for TX FIFO empty
9. Set CS to 1
10. Life is good
Thank's everybody for help :)
smarell
Community Manager
Community Manager
Can you tell me which command do you use for programming?
sirius13
Hello my dear. I'm using command with ID = 0x02, this is Page Program with 3 byte for address
P.S. Please clarify - why does command sequence
XQspiPs_WriteReg(QSPI_BASEADDR, QSPI_TX1, 0x02);
XQspiPs_WriteReg(QSPI_BASEADDR, QSPI_TX1, 0x030000AA);
QSPI_ManualStart() //my own function, initiate start
causes programming flash with AA-byte at address=0x03?
An this
XQspiPs_WriteReg(QSPI_BASEADDR, QSPI_TX2, 0x0300AAAA);
QSPI_ManualStart()
causes programming flash with AAAA-bytes at address=0x03?
sirius13
2. Set CS to 0
9. Set CS to 1
10. Life is good
