Question regarding to Xapp1017 for converting LVDS serial data to parallel data
We have used the example in Xapp1017 as reference to convert LVDS serial data to parallel data .
Currently, we have a question regarding to bitslip module; in UG471_7Series_SelectIO, it is mentioned updated parallel data is triggered by clock CLKDIV and bitslip.
In our hardware design output as attached in above figure, PIX_clk is the CLKDIV, SYNC_OUT is the output parallel data, but when bitslip is HIGH and PIX_clk is toggled HIGH, SYNC_OUT is not updated until few clocks after as marked in timing 2. Please let us know, how can we shift SYNC_OUT data to the correct position?
In the simulation result picture, SYNC_OUT is updated one clock after bitslip is HIGH and PIX_clk is toggled as marked timing 1 and 2.
Many thanks for any your suggestions.
David.
Re: Question regarding to Xapp1017 for converting LVDS serial data to parallel data
any suggestions?
