Newbie prasanup
Regarding PULLUP value provided by the PULLUP primitive in the VIVADO
Hello all,
I am implementing a design on VIRTEX7 xc7vx690Tffg1926-2  FPGA. PULLUP primitive is used as an instance connected to the one of the IO pins in top level rtl. Could anyone please tell the pullup value provided by the PULLUP instance..?
Prashanthi
Re: Regarding PULLUP value provided by the PULLUP primitive in the VIVADO
Hello @prasanup
YOu can calculate pull up resistor value from datasheet provide VCCO and IRPU value.
Rpullup = VCCO/IRPU
For more information check https://www.xilinx.com/support/answers/20484.html , https://www.xilinx.com/support/answers/67577.html
and http://www.xilinx.com/support/documentation/data_sheets/ds183_Virtex_7_Data_Sheet.pdf
Bhushan
Newbie prasanup
For the PULLUP value calculation the below formula is used
  • Rpu = Vcco / Irpu(max)
In the above formula why only maximum value of Irpu is considered?
Prashanthi
