Rising and Falling edge error
hi
I do not simulate
I want to lick both the rising and failing edge of the 1 entry How can I do this I'd try
if Signal_in'event and Signal_in='1' then
i <= i + 1;
elsif Signal_in2'event and Signal_in2='0' then
i <= i + 1;
end if;
if Signal_in'event then if Signal_in = '1' and edge_state=false then i <= i + 1;
edge_state <= true; elsif Signal_in = '0' and edge_state=true then i <= i + 1;
edge_state <= false;
end if;
end if;
not works
First, "not works" is a poor description of your problem.  Do you get an error message?  Is it a syntax check error, a synthesis error or an Implementation error?  What is the error message and what line in your code does it reference?
The only registers in a Xilinx FPGA that can respond to both the rising edge and falling edge of a clock are in the Input/Output tiles.  Registers inside the FPGA can only respond to one edge of a clock.
Your code has multiple registers driving the signal "i".  Only one register output may drive a signal.
Are Signal_in and Signal_in2 really clocks (constantly running periodic signals) or are they something else?  Using a regular signal as the clock input to a register is very bad design practice.
A few other comments
welcome to the world of VHDL.
You will love and hate the strict constraints, stick with it its worth it.
String suggestions
a) Dont use Signal_in'event and Signal_in='1'  , use if rising_edge( signal_in )
b) make certin this is inside a process with the correct sensetiity list
c) Always simulate...  Simulatoin is quicker than synthesis and tells you a lot more about your circuit . You will spend may be 60 % of your life simulating, 30 % designing, and 10 percent waiting for synthesis.
d) always rember that your code is describing hardware, if you can't think what the hardware is , the its likely the tools can not either.
( and yes there are no DDR flip flops in the FPGA )
Why do yo u want  DDR internal flipflops ?
@trnkttc,
i <= i + 1;
i <= i + 1;
end if;
Not possible to do within the FPGA.
Pay attention to what others have said above.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
