Observer sp_usr
Spartan 6 PAD to FF time at IOB
Hi all,
I'm porting a Spartan 3A design to a Spartan 6 and I see that timing results are so different for both architectures.
I have many input signals constrained by PAD to FF constraint to 3 ns which were quite easy to meet at S3A IOB and impossible(?) to meet by spartan 6 (-2 speed grade LVCMOS33).
I see the timing analyzer tool calculates this max time like:
Tiopi (≈ 1.59 ns) + net delay (≈ 0.3 ns) + Tidock (≈1.73ns) , which is correct according to Spartan 6 datasheet.
I see that there is another time at datasheet called Tidockd (instead of Tidock) that has slower time values. It talks about using IODELAY2.
I have been reading about this IODELAY2 primitive, but I do not have it clear. Is it possible to use this primitive for any IOB? And could I find a solution to meet this time requirement using this primitive(3 ns)?
Re: Spartan 6 PAD to FF time at IOB
@sp_usr
Near Fig 1-1 in UG381, it says that every I/O tile contains two IOBs, two ILOGICs, two OLOGICs, and two IODELAYs.  So yes, it is possible to use IODELAY2 with any IOB.
The IODELAY2 primitive provides adjustable and fine-resolution delay.  The IODELAY2 can be inserted between the IOB block and either the ILOGIC2 or OLOGIC2 block in Fig 1-1 of UG381 to increase delay (not decrease delay).
I have many input signals constrained by PAD to FF constraint to 3 ns..
I agree with your calculation of the Spartan-6 PAD-to-FF delay and it seems that your constraint of 3ns cannot be met (for -2 speed grade and LVCMOS33).  Can you tell me where this 3ns constraint is coming from?
If the 3ns constraint is coming from an FPGA clocked IO interface, then perhaps the constraint is not so strict.  That is, with FPGA IO, it is usually a delay-difference (between a data-path and a clock-path) that concerns us – and not the absolute delay of either path.  In fact, the IODELAY2 primitive is often used to adjust this delay-difference for FPGA IO so that the data is properly captured (ie. to locate the clock capture edge in the middle of the data eye).
Anyway, please tell me more about the 3ns delay requirement - then perhaps I can help you a little more.
Cheers,
Mark
