Spartan 7 - LVDS2.5V bidirectional interfacing with LVDS 3.3V input
  I am planning to use the Spartan-7 LVDS 2.5V for bi-directional LVDS input and output. However, the LVDS input coming into the Spartan-7 is at 3.3V level and the Spartan-7 only supports LVDS 2.5V. Will this be acceptable? I am planning to set VCCO to 2.5V.
   As for output, the LVDS level would be at 2.5V (I assume since this is an output from Spartan-7) and this output will be fed into the LCD Screen which has LVDS at 3.3V. I would like to know if this application for different LVDS voltage levels will work?
Thank you!
Re: Spartan 7 - LVDS2.5V bidirectional interfacing with LVDS 3.3V input
Hi @vivienwwp
LVDS signalling standard is independent of the supply voltage.
Check VOD (Differential) & VOCM (Common Mode) specification of your external device; which you are going to interface with Spartan 7 FPGA.
As per my knowledge, If they are within range of VID & VICM of the Spartan-7 then you can interface them to each other.
You can also check it by performing IBIS simulation.
EDIT1: Check https://www.xilinx.com/support/answers/43989.html for more details.
Bhushan
Bhushan
Hi @vivienwwp
Bhushan
Bhushan
OK thank you!
