Observer carruinar
Synchronization between two Virtex-7
I am doing a project and I need some ideas on how to synchronize data from 2 Virtex-7.
I have:
1. 2 high speed ADCs with the same clock but not synchronized between them.
2. Signal processing in the FPGA 1.
3. Signal processing in the FPGA 2.
4. Signal processing with samples 2 and 3. These samples must be synchronized.
* The FPGAs are connected by wires to introduce a delay.
I have thought about introducing a known signal in ADC1 and ADC2 and to use FPGA IODelays to synchronize, but  I don't know if it is the best option.
Thank you.
Re: Synchronization between two Virtex-7
you can use this IPs
http://www.xilinx.com/support/documentation/ip_documentation/axi_chip2chip/v4_2/pg067-axi-chip2chip.pdf
Thanks and Regards
Balkrishan
Observer carruinar
Thanks for the reply.
I need the maximum possible data stream speed. Is it better to use that Chip2Chip AURORA? I dont know when to choose to use one over the other.
Please check Table 55 (or) Table 70 based on the Virtex-7 device you are using. Aurora 64b66b supports maximum possible line rate that the device can support..
Aurora 8b10b supports up to 6.6Gbps
Observer carruinar
I mean that I don't know what are the benefits of using Chip2Chip or using AURORA. What things have to consider to choose one or the other?
It depends on your use case requirements. Can you check the product guide of Aurora and chip2chip?
One basic difference, AXI chip2chip is used with designs containing processors. If there is no processor in your design, you can use the Aurora IP.
