khyam
Through-silicon vias prototype in Artix 7 FPGA
How to prototype, through-silicon vias(TSV) module in FPGA. Just consider FPGA wire/link or any other way to module TSV in Artix 7 FPGA.
tenzinc
Khyam,
So, I am a little curious and concerned as to what the need for this information is. Would you care to share what you are trying to do here? I mainly ask because you question is in reference to Artix-7 and I am unaware of any documentation or Xilinx publication suggesting the use of TSVs for Artix-7 devices... As far as I know Virtex-7 were the ones with the silicon interposer and TSVs.
Regards.
Tezz
Get started FAST with our UltraFAST design methodoly guides and don't forget to visit our Xilinx Design Hubs for additional resources and reference.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
khyam
Design and implementation 3 Dimensional Network on chip architecture in FPGA. It uses vertical link(wire) as a TSV.
