Top-level design file becomes Non-module File
My top-level design file (Verilog) has been suddenly moved to Non-module Files. What could cause it? I have Vivado 2018.3.
Thank you.
Just found out that it was caused by the missed syntax typo in the signal list. So, the file was removed from the design hierarchy. It appears this may happen to any source file.
