rsgrimes
Two output signals on two different pins appear to be added together! (Zync XC7Z010)
I am trying to create a simple VHDL component that sends the output of a quadrature encoder on two pins (i.e. Phase A and Phase B). The component works, as illustrated here in the Vivado simulator:
SimulationSimulation
However, when I route those signals to two pins on my FPGA, using these constraints:
set_property PACKAGE_PIN G17 [get_ports {P_PHASE_A}];
set_property PACKAGE_PIN G18 [get_ports {P_PHASE_B}];
set_property IOSTANDARD LVCMOS33 [get_ports -of_objects [get_iobanks 35]];
I see the following on my scope:
Scope TracesScope Traces
It appears as if the two signals from my component are added together and sent to both pins! I suspect there is something I'm missing in the constaints file, as the two pins G17 and G18 apparently can be combined as an LVDS signal, which could explain what I am seeing; however, other signals on other LVDS-capable signals do not seem to exhibit the same behavior.
I am using a MicroZed 7010 (with XC7Z010-1CLG400C FPGA), mated with the AES-MBCC-IO-G I/O expander board, which simply brings the pins out to headers.
bruce_karaffa
The two pins are almost certainly shorted together somewhere.  They are not connected inside the FPGA.  I don't see anything in the schematic for the Microzed or expander board to account for this.
chaitusvk
Use ila core to Debug
mage
Do you set the VCCO_35 to 3.3V?
bruce_karaffa
rsgrimes
Embarrassed to admit, it was my scope probes that had shifted and caused the behavior! Doh! Thanks for prompting me to check another time.
