Observer dalepelletron
Unable to create slower clock with MMCM or PLL
My design runs mostly on 32/64MHz, but I have to forward  a serial clock to another device that runs at 4MHz. I am running into problems generating this clock from an MCMM or a PLL.
With the formula for Fvco being Fvco= Fclkin x M/D and the formula for each of the clockouts being Fout = Fclkin x M/(D x O), my problem is as follows. My clkin will be 32MHz  Fvco needs to be between 600 and 1440MHz, so lets say I set M to 20 to get a Fvco of 640Mhz. D can be left at 1, but to get a clockout of 4MHz, O needs to be 160 which is higher than the maximum of 128.
I have seen other posts describing a method of using a counter and a bufgce to create a slow clock, but that is for clocks in the kHz. 4MHz seems like a reasonable clock speed, what method would be simplest to create this? Is there a clocking feature that I have missed?
Thanks so much in advance.
Re: Unable to create slower clock with MMCM or PLL
Dalepelletron,
Couple options I'll list here but the first one is what I think you are looking for:
  1. Use CLKOUT4_CASCADE feature of the MMCM. This should let you get down all the way to 0.036MHz. Attached image below of the option from Clocking Wizard.
  2. You could aslo do what you've found out which is to use a BUFGCE and toggle the CE input every 2 clock cycles with a very small counter.
  3. Or you can see if you can run your other device design at a slightly higher clock frequency so it's above 4.69MHz.
T
Dalepelletron,
T
Visitor qcole5
Would checking that allow me to divide my single clock as much I would like (down to 0.036MHz)? Or do I need to have multiple clocks fed in?
