What are the storage capacities of BBRAM and eFuse? (7020)
Title explains the question. J could not find a document stating this information for the Zynq 7020. What are the sizes and what is the right document to check out?
Dosto
Tags (4)
lowearthorbit
No one is going to help,
This is proprietatary information, and would aid those attacking the device, or those trying to design their own.
Trade secrets.
l.e.o.
tenzinc
I recommend viewing XAPP1175 / XAPP1084 and the associated reference links for more detailed information. It should explain BBRAM and the eFuses(PL & PS) as well as your question about its "sizes" and much more. These are not really user accessible memory in a general sense and are meant for secure boot for tamper resistant designs/applications.
Get started FAST with our UltraFAST design methodoly guides and don't forget to visit our Xilinx Design Hubs for additional resources and reference.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
Thanks for the answer, however I couldn't find the size info in those documents.
Dosto
tenzinc
There is a table right in one of the Xapps breaking it down... BBRAM and eFUSE strore encryption keys of size 256-bits. The PS eFuse/RSA is a little bit more complicated and I recommend viewing chapter 32: Device Secure Boot of the Zynq TRM for more info. Should give you much more detail and understainding about the secure boot process and how the RSA keys play into it.
T
lowearthorbit
Trade secrets.
l.e.o.
Thanks for the help,
I saw that table. However, I couldn't be sure; the exact size is not crystal clear IMHO. Anyway, we know their lower bounds; they must be capable of holding at least 256 bit data. lowearthorbit seems right, so I won't dig into further.
Dosto
