Where can I find the gate primitives in verilog for stanard cells?
I was try to study a bit on the type of flops used for KC705. However where can I find the standard cells primitives verilog file in the Vivado\2014.3.1\data\parts\xilinx\kintex7 directory?
Re: Where can I find the gate primitives in verilog for stanard cells?
@zerro_power
You can only use the RTL instantiation primitives of cells in Vivado. Check this link for 7 series:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug953-vivado-7series-libraries.pdf
--Syed
@zerro_power
--Syed
