Writing code into QSPI
My design is based on XC7Z035FF900 and I am using the same two QSPIs and connections as in ZC706.
I am wondering may I write booting code into two QSPIs as in document "restoring-flash-c-2015-4.pdf"?
Can I replace FPGA.bit file with XC7Z035FF900 version to get the QSPI and FPGA configured properlly?
Many thanks for your answers.
David.
Re: Writing code into QSPI
So you have a zynq device and you've got the PL design bit file and also some embedded software so maybe an FSBL and an application and you want it to boot everything off the QSPI.
For sure you can use SDK to create a boot image. Take a look here
https://www.xilinx.com/video/soc/create-zynq-boot-image-using-xilinx-sdk.html
I'm not sure how to treat 2 x QSPI as one memory space
Dear Klumsde,
Yes, you are right.
I am going to usse SDK to program QSPI.
Many thanks.
David.
