Visitor rua
XADC VP/VN voltage measurement value unchanged
I am using XADC IP to do voltage measurement, but the detected values remains unchanged no matter where I put the test point, even when the circuit is unpowered.
Anyone no the solution to this problem?
This is my block design
This is my SDK code
this is the test result I got
Re: XADC VP/VN voltage measurement value unchanged
Hi @rua
when you are connected to the board can you check the JTAG and see if you can add the vp/vn to the XADC console for plotting. if it is not changing there then it points that the XADC is not updating due to the fact that VP/VN is not in the sequence.
I am confused about your settings. It looks like you have it set up in single channel mode but also have the external mux bit enabled.
Change the register 40 so that the mux bit is not set.
If you read the UG you will see that the extenal mux will mux in AUX channels via the dedicated inputs and the result appears in the results register for that AUX channel.
