XADC simulation with VAUX external outputs
Hello I'm having trouble simulating with the VAUX external inputs. I have a XADC design source, test bench, and design.txt, but I'm not getting any outputs.  Ive referenced ug480 and XADC wizard user guides and I'm not seeing much regarding VAUX exertnal input simulation.  I've been advised to initialize,
.INIT_40(16'h0416), // config reg 0
.SIM_MONITOR_FILE("design.txt")
 but I'm not getting any changes to the VAUX ports. I've attached my design source and test bench. Please help.
Re: XADC simulation with VAUX external outputs
Hi @2k17_hghspdsrmg
Can you please also share you analog stimulus file (design.txt) ?   are you constructing  this file according to given in user guide in example test bench section ?
