Xilinx Shelf life information > 2 years.
Flex would like to know if Xilinx has assurance if the shelf life is valid for longer than 2 years. As we know, some manufacturers give assurance that their parts are good for up to 5 years. Kindly share in details if Xilinx having any policy for shelf life valid longer than 2 years. Example as per attached.
MPN
XC6SLX16-2CPG196I
XC7A50T-2CSG325I
XC7A50T-2CPG236I
Example Policy from NXP
https://www.nxp.com/docs/en/supporting-information/NXP-Shelf-Life-Policy-2020.pdf
Example Policy from Lattice
https://www.latticesemi.com/view_document?document_id=50316#:~:text=The%20best%20indication%20of%20shelf,and%20repackaging%20with%20fresh%20desiccant
Sean
Re: Xilinx Shelf life information > 2 years.
Hello @Sean-T
Kindly check for high temperature storage life in UG116 Table 62.
You may also find AR#18120 useful.
Bhushan
