immi4net
Zedboard ADC LVDS interfacing
 I am trying to interface 14bit ADC, Its single wire diffferential interface @ 4MSPS  rate clocked at DDR(Attached). I am trying to understand the XAPP524 and its vary complex and confusing. Can anyone recommend me for how to simply interface my ADC with ZYNQ on PMOD connector.
https://www.dropbox.com/sh/n7ahzdy2cszydr4/AADtuGbj08rV-kKxM-xbp1noa?dl=0
balkris
check this example design
https://wiki.analog.com/resources/fpga/xilinx/pmod/ad7476a
Thanks and Regards
Balkrishan
immi4net
thanx for your reply, I hv already gone alot of  AD reference design and they all use only single data rate for thier ADCs so they are not using SerDes/IOBUFG/ and Idelay etc.
I just need a simple example of interfacing double data rate on differential LVDS.
balkris
you can refer this XAPP target for virtex-6
XAPP1071 - Connecting Virtex-6 FPGAs to ADCs with Serial LVDS Interfaces and DACs with Parallel LVDS Interfaces Application Note ( ver1.0, 1489 KB ) [PDF]
Thanks and Regards
Balkrishan
immi4net
Its for virtex devices but i am trying to interface with & series ZYNQ. Why this LVDS interfacing is so complex?
