Zynq 7000 - XC7Z030 MIO State at startup
I wanted to know more about the state of the PS MIO at startup. I saw several answer on other topics but nothing that is really clear about this.
The TRM state at table 6-18 that at boot the IO from 9 to 53 are in tri-state input with a pull-up, but it isn't stated elsewhere. Can someone point me to another clue about this behaviour ?
We are physically seeing that the MIO signals are high when the zynq is unconfigured (blank) which is the same as when it boots up.
Thank for the information
If you look at the register map in the TRM appendix you can see the reset state of the MIO pin.
It indeed resets a state where the output is High-Z and the pull up is enabled.
Keith
Keith
