Observer linlf369
can asynchronous BPI flash meet the requirement of pcie ip core
hi, everybody,
     I have a pcie card, which can transfer data to the computer via pcie bus. A pcie IP core is used。 As xilinx data sheet said, the configuration files must be loaded within 100ms, otherwise the computer would fail to recognize the pcie card. A BPI flash which can work in synchronous mode is recommended.
     But all the Micron flash which can work in synchronous mode, is in the end of life. the alternatives is a flash only can work in asynchronous mode.
     So can asynchronous  BPI flash meet the requirement of 100ms?
Re: can asynchronous BPI flash meet the requirement of pcie ip core
you need to use the tandem configuration so that you can meet 100ms requirement for 7-series/ultrascale devices
check the following link for details on tandem
https://www.xilinx.com/support/documentation/application_notes/xapp1179-tandem-config-pcie.pdf
Observer linlf369
hi,
    thanks for your reply.
    is that the only method to meet the requirement of Pcie IP core?
    I am wondering why Micron threw all the flash which Supports synchronous mode into end of life......
