fault injection in FPGA
As i wanted to do my project on ZYNQ fpga and wanted to purchase the xilinx product for the purpose mentioned.
i want to know which fpga in zynq family has the provision for fault injection and
the bit stream encryption of the plain data.
please do the needful. indeed for your response.
dpaul24
undelavanaja@gmail.com,
I had replied to a similar post yesterday?
https://forums.xilinx.com/t5/Open-Source-and-Community/fault-injection/m-p/968345#M475
Seems like you are guys from the same school working on a common project...............
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
Sir, I have gone through the link posted by you. but they are showing the fault injection provision is supported by spartan-6 and artix. But I need the details regarding the Zynq fpga, which is of my concern and the encrypted bit stream details which is not given in the link provided by you sir
Please do the needful sir
