fir filter output
 I written Verilog code for FIR filter by circular convolution with 1K samples, but its taking settling time for every cycle, i am unable to find out the problem any body can suggest me
Voyager
Voyager
Re: fir filter output
you must be flushing your pipeline or resetting it somehow. Is it vhdl/ verilog you could share?
thank you for ur reply sir,
   ya what u told its correct only, I am resetting it at k=1023 (sample size is 1k).
if I didn't reset it at k=1023, the result will add to previous output and my waveform its look like ramp sine wave. so I am resetting it.
Voyager
Voyager
narendrandesainath@gmail.com
So I guess this is the cause of your settling time, FIR filters have latency. Below is a FIR filter (one of the implementations). After a reset, you need to clock data N times to have an actual value at the output of the last delay box, otherwise you have zero.
