kready
k7 cant load mcs file
Dear members;
I am trying to program the flash (Winbond W25Q32BV ) using SPI with the Impact(ise 14.5).
I can successfully read the device status.  I can erase the device  and can successfully program bit file.
But when I use JTAG Port to program mcs file, it shows :"...was not successful, Done did not go high."
here is log file :
GUI --- Auto connect to cable...
INFO:iMPACT - Connecting to TCF agent...
INFO:iMPACT - Digilent Plugin: Plugin Version: 2.4.4
INFO:iMPACT - Digilent Plugin: no JTAG device was found.
AutoDetecting cable. Please wait.
*** WARNING ***: When port is set to auto detect mode, cable speed is set to default 6 MHz regardless of explicit arguments supplied for setting the baud rates
PROGRESS_START - Starting Operation.
Cable is LOCKED. Retrying...
Connecting to cable (Usb Port - USB21).
Checking cable driver.
Driver file xusb_xlp.sys found.
Driver version: src=1029, dest=1029.
Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 x86_64 64bit SYS 14:14:44, version = 1021.
Cable PID = 0008.
Max current requested during enumeration is 74 mA.
Type = 0x0004.
Cable Type = 3, Revision = 0.
Setting cable speed to 6 MHz.
Cable connection established.
Firmware version = 1303.
File version of d:/Xilinx/14.5/ISE_DS/ISE/data/xusb_xlp.hex = 1303.
Firmware hex file version = 1303.
PLD file version = 0012h.
PLD version = 0012h.
PROGRESS_END - End Operation.
Elapsed time =     1 sec.
Type = 0x0004.
ESN device is not available for this cable.
Attempting to identify devices in the boundary-scan chain configuration...
INFO:iMPACT - Current time: 2015/3/4 10:45:49
Identifying chain contents...'0': : Manufacturer's ID = Xilinx xc7k70t, Version : 0
INFO:iMPACT:1777 -
Reading d:/Xilinx/14.5/ISE_DS/ISE/kintex7/data/xc7k70t.bsd...
INFO:iMPACT - Using CseAdapterBSDevice
INFO:iMPACT:501 - '1': Added Device xc7k70t successfully.
done.
Elapsed time =     0 sec.
Selected part: W25Q32BV
Unprotect sectors: FALSE
INFO:iMPACT - Current time: 2015/3/4 10:46:21
Maximum TCK operating frequency for this device chain: 66000000.
Validating chain...
Boundary-scan chain validated successfully.
1: Device Temperature: Current Reading: -273.00 C
1: VCCINT Supply: Current Reading:   0.000 V
1: VCCAUX Supply: Current Reading:   0.000 V
Not an xsdb core.
Core is not loaded.
INFO:iMPACT - Downloading d:\Xilinx\14.5\ISE_DS\ISE\data\cse\cseflash\kintex7\xc7k70t_xsdbspi.cor core file.
INFO:iMPACT - Creating XC7K70T device.
'1': Programming device...
Match_cycle = NoWait.
Match cycle: NoWait
LCK_cycle = NoWait.
LCK cycle: NoWait
done.
INFO:Cse - Status register values:
INFO:Cse - 0011 1111 1001 1110 0000 1000 0000 0010
INFO:Cse - '1': Completed downloading bit file to device.
INFO:Cse - '1': Programming completed successfully.
key: period_frc, value: 0
key: dclk_has_reset, value: 0
key: period_int, value: 10
Found Slave on Bus Index.
SPI core clock speed value = 0xA801.
'1': IDCODE is 'ef4016' (in hex).
'1': ID Check passed.
'1': Erasing Device.
'1': Using Sector Erase.
'1': Erasing non-volatile quad-enable bit...
'1': Programming Flash.
'1': Reading device contents...
done.
'1': Verification completed.
'1':Programming in x1 mode.
W25Q32BV Status Register Contents = 0x0002.
QUAD ENABLE                                      :         0
STATUS REGISTER PROTECT 1                         :         0
STATUS REGISTER PROTECT 0                         :         0
SECTOR PROTECT                                   :         0
TOP/BOTTOM PROTECT                               :        0
BLOCK PROTECT BIT 2                               :         0
BLOCK PROTECT BIT 1                               :         0
BLOCK PROTECT BIT 0                               :         0
Elapsed time =   338 sec.
'1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and mode settings.
Any help is appreciated.
kkn
what is the mode pin settings? it should m[2:0] = "001" for spi configuration
--Krishna
kready
yes
kready
vuppala
Can you try reducing the cable speed?
Vinay
kkn
can you do power cycle of the board(power off and on) and if configuration fails can you capture the status registers from impact and attach to this thread.
Also compare the readback file of the flash with original mcs file and see if there is any difference.
--Krishna
kready
I switch the flash which had load mcs file to the board, the FPGA can't load the code from flash when i power cycle the board.But when i short R198 for few time, FPGA can load mcs file.
vuppala
Hello
Do you mean when you connect PROGRAM_B connects to GND, the mcs files loads successfully to FPGA??
Vinay
kready
yes
