Newbie lixiaoqing
"ERROR: [Updatemem 57-156] Update_mem does not support encrypted bitfile" in Artix-7 FPGA
I want to encrypt bitstream generated from a Vivado design. The FPGA type is Artix-7. I use the eFUSE encrypt  mode. The project without microbaze was OK  ,and encryption operation was valid.
But when I add a microblaze into the project and use "program FPGA" in SDK, in order to merge .bit and .elf files ,there was an error. How can I do if I want to continue?
Thanks for help.
The information in microblaze SDK is:
****** updatemem v2017.4 (64-bit)
**** SW Build 2086221 on Fri Dec 15 20:55:39 MST 2017
** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved.
source C:/Xilinx/SDK/2017.4/scripts/updatemem/main.tcl -notrace
Loading bitfile E:/SVN/Local_PrjBuff/FCOM/FCOM/prj.runs/impl_1/top.bit
ERROR: [Updatemem 57-156] Update_mem does not support encrypted bitfile E:/SVN/Local_PrjBuff/FCOM/FCOM/prj.runs/impl_1/top.bit.
ERROR: [Common 17-39] 'update_mem' failed due to earlier errors.
Re: "ERROR: [Updatemem 57-156] Update_mem does not support encrypted bitfile" in Artix-7 FPGA
The error message is correct , updatemem does not support encrypted bitstreams.
You will need to associate the elf in Vivado (not use updatemem), and then this will be encrypted
See Page 160:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug898-vivado-embedded-design.pdf
In summary, there are two ways in the tools to populate the BRAM; Associating the ELF in Vivado, or updatemem.
Since updatemem doesn't support encryption, then you must use the other method.
Newbie lixiaoqing
Thank you! I will try it.
