simple GTX tranceiver configuration: Error count Signal
I changed data in "gt_rom_init_tx.dat" and the same changed data is copied into "gt_rom_init_rx.dat" file and I also made sure that there are enough transitions in changed bytes. I didn't alter the whole data file, I altered one portion of it. Actual data "000000003e3d3c3b0000" and changed it to "00000000060504970000" data in both TX and RX file.
I am expecting no errors but, in simulation I am observing error. Without doing this it's all working fine. Where I am going wrong?
It's written in the UG if needed ".dat" files can be modified by the user.
Second problem is  gt0_rxcommadet_i  toggling even for unmodified data where there are no errors. Isn't this signal should remain 1 after comma is detected?
Thank you.
Re: simple GTX tranceiver configuration: Error count Signal
rxcommadet is not a sticky output. It will be high only for the cycle in which comma character is found.
Do you exactly match tx and rx .dat files? You can go in depth to observe the signals from frame_check module to exactly check the expected data and the received data to confirm your edits are fine.
@venkata
Yes I did match the data... for example when I rechange it to default data then I don't get any error.
I opened these files location and changed the data and saved it. Did I do it correctly?
For all, I used default GT wizard example and altered "gt_rom_init_tx.dat" and "gt_rom_init_tx.dat" files. But I made sure that both are same.
Your approach to edit "gt_rom_init_tx.dat" and "gt_rom_init_rx.dat" files is correct. To understand your observations, check the signals form frame_check module. The error count will increment when the received data is not matching with "gt_rom_init_rx.dat". Check if the sequence is missing synchronization.
These are the results for default GT wizard exaple design. I didn't change the ".dat" file, TX and RX are not matched or they are out of synchronous? But this is error free simulation, according to UG, track data goes high.
How CDR_lock functions? because, If I change ".dat" file to all zeros, still CDR_lock signal goes high. I am expecting it to go to zero when there are no enough transitions in data.
Hi @venkata
Did you find any solution for this problem? Still I am not  able to solve this.
regards.
Please attach your project with error. I will review and get back.
Hi @venkata
Do you mean .xpr files? If so, here I have attached "projectencoder_2.xpr" and "gtwizardscrambler_2_example.xpr". The first one is peoject and the later is example design.
with just .xpr files, I cannot reproduce your observations. Please archive your projects and attach them. Both example and after your edits.
Hi @venkata
I am unable to attach files in a single folder.so, i am zipping it into two zip folders. while extracting please make sure that destination folder for both the zip files should be same.
Hi @venkata
Did you find any solution for this problem? Is there a problem with the tool or hardware? or Am I doing simulations wronglly?
regards,
shashank
