want some example and guidance of GTX
I'm learning GTx/GTH now and want to find some help. I use VC709and can see some design examples of PCIE, MIG..., but there's no any guidance of GTH. If someone can give me some examples or guidances I will be appreciated.
Re: want some example and guidance of GTX
Hello @shabbulife,
You can start with below user guide to understand details of the functional blocks inside GTH -
https://www.xilinx.com/support/documentation/user_guides/ug476_7Series_Transceivers.pdf
Coming to the implementation part, you can refer below application note which describes how to implement transceiver wizard example design on KC705 board. On the similar lines, you can build and test design for VC709 board.
https://www.xilinx.com/support/documentation/application_notes/xapp1200-k7-xcvr-wiz-example-design.pdf
For the details about transceiver wizard IP, you can have a look at below PG -
http://www.xilinx.com/support/documentation/ip_documentation/gtwizard/v3_6/pg168-gtwizard.pdf
Ashish
Hello @shabbulife,
Ashish
Refer this document
refer this ARs
https://www.xilinx.com/support/answers/57260.html
this may be useful
https://www.xilinx.com/support/documentation-navigation/design-hubs.html
Thanks and Regards
Balkrishan
Hello @shabbulife,
Did the responses help to address your query?
Ashish
 Thank you for your links and I successfully generate bit files. However, I confront a new problem. I cannot open the chipscope because it says that Unable to arm ILA 'hw_ila_5'. The core clock is slow or no core clock connected for this ILA or the ILA core may not meet timing. Is something wrong with my clock restriction?
