xapp524 - Will xapp524 work for 1 wire and 12/14 bit ddr mode?
 The xapp524 reference design, will it work in FPGA for 1 wire mode? Because I have doubt on frame clock block. Is anybody proved in FPGA?
Table 1 in the XAPP shows the valid combinations for Resolution/sample rate/bit clock rate/1-wire or 2-wire mode.
 As per logic of Frame clock block, The derived frame clock from BUFR should vary according to mode (1 wire or 2 wire). But it doesn't happen in the provided design. Kindly reply to this query.
I  have test 1-wire mode and it does not work.
my adc is afe5818, and it's configured to output DDR 16bit mode serial lvds.  xapp524 did not work
