zc706 turns off after FPGA programming
Hi everybody,
I have a wired problem. I program Zynq FPGA on ZC706 and the board get turned off!!!
The implemented design is an 1-lane Aurora core and the SMA pins are looped back.
Board is OK and only this design causes the problem.
Re: zc706 turns off after FPGA programming
What is the estimated power?
Seems unlikely, but if the power draw is too great, the supplies shut down.  I have also seen the power vary at the natural frequency of the device/board PDN (usually around 33 KHz) where the resonance also trips the POR (look at the power rail for Vccint).
The above applies to all devices, all boards.
Farzian,
Can you isolate the event in some way? Is it right after programming or a little after it? What about on a cold vs warm boot? Does it reliably happen with soft or hard power cycle? Can you use the SYSMON to read out the junction temp via impact or Vivado??? You may want to run through the board debug AR for the ZC706 to make sure that the board is not compromised in any way.
https://www.xilinx.com/support/answers/54013.html
Tezz
