57-bit DEVICE_DNA, 64-bit FUSE_DNA, and Endianness
Because I was very confused by this, I am sharing the following. These observations are the result of trial and error:
  1. FUSE_DNA is a 64-bit big-endian vector, i.e. [0:63]
  2. DEVICE_DNA is a 57-bit big-endian vector, i.e. [0:56]
  3. FUSE_DNA[7:63] == DEVICE_DNA[0:56]
  4. DNA_PORT shifts out bit 56 of DEVICE_DNA first
  5. Impact’s ‘readefuse’ command outputs DEVICE_DNA in hex, treating bit 56 as leftmost/most significant
  6. The method of AR# 64178 (Vivado) reports both FUSE_DNA and DEVICE_DNA/DNA_PORT in hex, treating bit 0 as leftmost/most significant
Re: 57-bit DEVICE_DNA, 64-bit FUSE_DNA, and Endianness
Hello @vertreko
1. FUSE_DNA [63:7] == DEVICE_DNA [0:56]
2. Check this answer record: http://www.xilinx.com/support/answers/64847.html
Vinay
Hello @vertreko
Vinay
My post was about how to interpret
  1. Vivado::REGISTER.EFUSE.FUSE_DNA
  2. Vivado::REGISTER.EFUSE.DNA_PORT
  3. Impact 'readefuse -dna'
  4. Fabric DNA_PORT
3 and 4 above match each other.
AR# 64847 needs to be more careful about what it means by DNA_PORT (2 vs 4 above).
vivado_fuse_dna     = 2A0E9544310F1A1F
vivado_dna_port     = 0541D2A88621E34
impact_device_dna   = 0058F08C22A97054
Try 0
vivado_fuse_dna     forward 0010101000001110100101010100010000110001000011110001101000011111
vivado_dna_port     forward        001010100000111010010101010001000011000100001111000110100
impact_device_dna   forward        001011000111100001000110000100010101010010111000001010100
Try 1
vivado_fuse_dna     reverse 1111100001011000111100001000110000100010101010010111000001010100
Try 2
vivado_dna_port     reverse        001011000111100001000110000100010101010010111000001010100
Try 3
Try 4
impact_device_dna   reverse        001010100000111010010101010001000011000100001111000110100
Try 5
Try 6
Try 7
Note that Try 3 worked
Scholar trenz-al
I used trial method too.
and please note that you shoud only check with Vivado and NOT pay attention to software product abondoned in 2013 (impact..) there are no updates to impact since 2013.
I don't know. At least Impact will remain consistent :). I'm using Vivado 2015.1, but according to AR# 64847:
Beginning in Vivado 2015.3, no manual manipulation of the Vivado displayed value will be required.
Vivado Device Programmer will display the regrouped MSB:LSB value that the Simulation model returns on the DOUT pin.
Does anybody know where we can obtain the extra 7 bits that vivado_fuse_dna contains? I would like if I could readback the full fuse_dna value in my design to verify it matches what Vivado shows.
Observer kwame.kyere
Please were you able to figure out how to get the 7 LSB?
Could you please share?
Thank you :)
