Visitor val_r
SDIF-3 Audio Interface - help a newbie
Hi folks!
I'm a newbie, very new to the exciting FPGA-VHDL design world, trying to design an encoder for the SDIF-3 audio coding (a sort of Manchester coding scheme), -code attached-
Signal generated from an external audio ADC board must get encoded by this design.
Simulation actually works just fine.
I'm actually using a Basys3/Artix 7 to experiment, then I'm planning to migrate to a CPLD.
From the official Sony's document, this is what the SDIF3 encoding does:
Since the A/D conversion chip already works with an external MCLK, I thought to use it to generate an internally divided
i_clk which is a double-data bit rate, i.e. the 'Clock' signal in the above picture.
Unfortunately, because of skew (I think), encoding is prone to error.
The following is a scope snap of "data_l" input (ch1, yellow), and the encoded output "out_l" (ch2, blue):
not quite correct! :(
I did measure the dsd bitclock generated from the ADC board, and the "i_clk" divided DDR clock, which governs the process,
I've measured around 21ns of skew.
The following snap shows i_clk(ch1), and dsdclk (ch2, blue):
Can this be the cause of uncorrect encoding?
What would be the best way to correct this? Re-sync dsd-data to i_clk? how?
Please see my code attached below.
Any hint/help greatly appreciated!
Visitor val_r
Re: SDIF-3 Audio Interface - help a newbie
Okay, changed little things in my new code (attached):
initialized  y_reg signal to '0', assigned DFF outputs to out_l and out_r instead of passing through intermediate signals.
Now it seems to work smoothly for the DSD 1x stream, (2.8224MHz original data, 5.6448MHz internal clock i_clk ).
In this configuration the external 22.5792MHz clock is divided by 4 to get the 5.6448MHz internal clock.
In the DSD 2x configuration, where the original data stream is doubled, at 5.6448Mbps, and i_clk is 11.2896MHz, being divided by 2 from the external Master clock,
I encounter a sync problem, the internal divided clock, i_clk , switches a little before the datastream transitions, causing incorrect coding.
The following is the scope snap of incorrect 5.6Mbps encoding, Ch1 (yellow) is the original input data stream,
Ch 2 (blue) is the encoded stream:
and the snap of datastream (yellow), against out-of-sync i_clk (blue):
clock is leading data.
Correct encoding should look like the following snap (at 2.8224Mbps):
How can I correct this?
Any hint?
Thank you in advance!
Visitor val_r
Anyone?
